Appleはスリムダウンして性能を上げたiPad Airを2013年11月1日に発表しました。スペースグレーとシルバーの2色から選べます。カスタムA7 プロセッサー搭載しており、容量は16、32、64と128 GBがあります。
502の回答 すべて表示
iPad Air Screen Broken into THOUSANDS of bits
Will the replacement instructions work if my screen is pulverized into thousands of pieces? It doesn't seem I'll be able to pry and suction cup anything. Would there be alternative instructions?
I'm looking at repair instructions for "iPad Air Wi-Fi Front Panel Assembly Replacement" by Author: Sam Lionheart. iPad Air Wi-Fiモデルのフロントパネルアセンブリの交換
Thanks!
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
First have a good working area because that glass is going to get everywhere. If you don't have experience repairing iPads stay away from the metal tools, because you will go in to far and cause damage to the LCD. Use lots of heat and plastic tools or even playing cards. Those severely broken screen are a pain but go slow and lots of heat.
この回答は役に立ちましたか?
スコア 2
コメント:
Thank you! I like the playing card suggestion
による
コメントを追加
最も参考になった回答
Yeah it will work. You will need to get something like an iSeasmo tool to get inbetween the frame and glass. You might also scratch the metal frame(probably screwed up anyway).
Please make sure your LCD screen still works fine, because otherwise you will need to replace the entire display and glass digitizer.
この回答は役に立ちましたか?
スコア 2
コメント:
Jake, thanks. Oddly, the LCD look fine thru the haze of broken glass. I will look for the tool you suggested.
による
コメントを追加
I successfully completed my repair, today. It really wasn't too difficult. Managing and removing pulverized glass was the most tedious part. Both Jake's and DC LifeTech's suggestions were helpful... lot's of heat, glass safety measures and a strong device for cleaning glass from the edges... I used a very good sharp pen knife (I'm an olde-timer!)
Due to extensive glass pulverization... the center of the broken glass was removed 'close' to the edges. Then, I slowly removed the remaining glass from the edges with lot's of heat.
The kit I purchased (iPad Air Front Glass/Digitizer Touch Panel Full Assembly ) had a new home bottom. So, I didn't need to be careful to conserve the old one.
I did the repair while pleasantly listening on radio to Martin Brodeur’s no. 30 being retired... raised to rafters at "The Rock" (Prudential Center) .... the whole ceremony... and, part of the subsequent match with the Edmonton Oilers....
この回答は役に立ちましたか?
スコア 2
コメント:
Glad to here it! Fixing is an amazing thing to do, congrats!
による
コメントを追加
回答を追加する
negocios0rsk さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 164
