メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
2014年9月19日に発売されたこのiPhoneは4.7インチのスクリーンサイズでiPhone 6 Plusの縮小版です。
5065の回答 すべてを表示
iPhone 6 not turning on - tried almost everything
Hey iFixit Team,
I purchased an iPhone 6 which was not turning on. It had a cracked screen and once opening up I could tell the battery had been replaced.
I replaced the battery and screen with genuine parts from an iCloud locked iPhone 6. I got the phone turning on but it was running slightly hot and draining faster than normal.
I restored the software from recovery mode and the problem persisted. Now the phone does not turn on after I left it dead for a while. I know I could probably get it to turn on if I put a charged battery in but I would like to fix the root cause. I have a feeling it might be a motherboard issue but would like to seek clarification and advice...
I have careful performed the screen replacement and reinstalled the battery with the proper apple adhesive strips so I should be able to get a replacement from apple if I can't get it fixed.
Thanks again,
Nick
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
1 件の回答
選択されたソリューション
Your answer lies within your question "I got the phone turning on but it was running slightly hot and draining faster than normal"
And now the battery has died it won't charge.
These are clear symptoms of a damaged U2 IC:
- Fast draining battery
- won't charge when dead
- phone getting hot
You need to replace the U2 IC, and this should solve your problem, this requires knowledge and the equipment to do microsoldering. :-)
この回答は役に立ちましたか?
スコア 2
コメント:
Thanks for the quick reply! That doesn't sound like a repair I could perform or do you think it is worth learning? I might see if apple can replace it..
さんによる
It requires pretty expensive equipment, decent microscope, decent soldering iron and reflow station, decent solder and flux, etc.
You can try Apple and see if they will replace the device.
さんによる
Thank you, will try apple and let you know how I go!
さんによる
コメントを追加
回答を追加する
nickb1994 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 224
