メインコンテンツにスキップ
Second of its generation, released in November, 2011, the Sony SLT Alpha-65V is a SLT (Translucent Mirror Technology) camera with a Sony Alpha/Minolta lens mount.
12回答 すべてを表示
SD card can't be inserted
Hi guys,
I think I have ruined my camera SD card slot, the SD-card can't be inserted , when I push it into the slot, it return back without getting in place. even I can't hear any click to let me know that the SD card is in place.
How can I repair this? do I need a new spare parts? any reference parts number?
Thanks a lot
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Did you try inserting it the other way? It will only fit in one way.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check the slot with another card...it could be a small part of the card has broken off...never force a card into a slot...if it still won't click home...worse case scenario...use a flashlight and look into the gap of the card holder to see if the metal tongues are misaligned...If they are bent out if shape...then you can try Luton Cameras for spares....they usually supply for canon and Olympus but sometimes keep Minolta Sony bits or will direct you to another source...lastly go to eBay and see if you can source a spare and repair Sony Alpha...
I think most Minolta models use the same module for card slot holders.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mhamdani さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 22
今までの合計 587
