メインコンテンツにスキップ
HP ProBook 4320t manufactured in May of 2010.
6回答 すべてを表示
Can't remove CPU heatsink because two of the screw heads are damaged
I replaced the thermal paste on the CPU and Radeon chip in a 4320s a couple years ago due to over heating causing shutdown on boot which fixed the issue.
It's happening again but this time I can't remove the heat sink because two of the screws holding it in place are damaged and won't turn no matter what screwdriver I try. The driver just spins in the head of the screw.
Any advice would be greatly appreciated.
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Have you tried these:http://www.amazon.com/Alden-8440P-Grabit...
Or use a round disc bit to carefully grind a line in the screw with a dremel so the screwdriver will grip?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zayn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 568
