メインコンテンツにスキップ
Repair information and troubleshooting for the HP Compaq Presario C700. This is a budget laptop made in 2008 as part of the Compaq Presario series of notebook computers.
22回答 すべてを表示
Scam preventing access to files/documents
My computer has been scammed and i cannot access my files/documents..
message says the files have been been protected by a strong encryptioin with RSA-4096 ..
I understand this is a scam that has been going for a few years...
What can i do ???
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Mary is there two problems ? the overheating power adapter and the ransom ware . As for the power adapter how hot is it and does it get that way when you first turn it on or does it take some time to heat up? Does the computer seem to run hotter as well ? Does it seem to be harder to plug in to the laptop?
The ransom ware is an ongoing problem that is a hard fix . The fixes that are out right now are not that effective and can end up with you loosing all your info. what I would suggest to you is buying a new hard drive and having a new OS installed ,start fresh and setting the old one aside until a fix is found to rescue you info safely. If there was not any important data on the computer or you were smart and had it all backed up, you can just reformat it and that will wipe the drive clean and a new fresh OS can be installed. At this point in time there is no safe fix that can guarantee getting your info back
Hope this helps
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Mary Brigg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 70
