メインコンテンツにスキップ
Portable wireless speakers from Logitech released in 2013.
64の回答 すべてを表示
Why does my bluetooth cut out?
When ever I raise volume to over about 65 % I hear then drum signal and my bluetooth cuts out. It keeps trying reconnect but cuts out again. Once I lower the volume it's holds a bluetooth connection.
My Device is always really close to speaker, distance is not the issue.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
My speaker keeps cutting out every 10 seconds. The music cuts out then just gets loud again every 10-20 seconds. I’ve only had this speaker for 3 years
by
Good question. Mine is now doing the same thing. Have you found a fix? I have reset and re-paired the Bluetooth but still same issues. So annoying.
by
Why does My bluetooth mouse cut out every once in a while
by
コメントを追加
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
選択されたソリューション
Hi,
Just wondering if it is a power issue. Can you connect a charger and then turn up the volume past the 65% level? If it stays on, my thinking is that the battery cannot power the volume at that level and maintain the Bluetooth connection. Even though the battery may be fully charged it may be failing under load. How old is the battery?
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Christopher rodriguez さん、ありがとうございました!
統計データを表示:
過去 24時間: 8
過去 7 日: 66
過去 30 日: 194
今までの合計 7,395
