メインコンテンツにスキップ
Can I fix the readout screen light on my Livescribe Echo?
The light gradually faded and now it is essentially nonexistant. I love the pen, but this is my second one and both have have malfunctioned.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
コメントを追加
9件の回答
最も参考になった回答
I found this about a replacement LED - http://amasci.com/elect/livescribe.html
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you for the tutorial, now I just need to find a pen with an OLED that is still bright enough to be useful ... cheers 8)
さんによる
コメントを追加
The livescribe OLED-Display is cheapest cr** - not perfectly sealed, oxygen and especially atmospheric humidity can rapidly degrade the organic light-emitting materials inside. Livecribe has proven :(
I got my pen replaced by livescribe (warranty) just to see it fade shortly after the original warranty period expired.
You can disassemble the Pen, but i found no replacement for the display so far... I can't imagine that this is a proprietary part made just and only for livescribe, so somewhere in this world there must be an OEM part. Maybe someone else has an idea?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have exactly the same problem and so far I have been unable to source a replacement screen ... I will continue to hunt for this elusive part ....
さんによる
I have the same problem,I was just about to buy a new one but am thinking will it go the same way
さんによる
コメントを追加
Buydisplay.com has some small OLED displays that might work. If I find one successfully I'll post it. If someone finds it first, please post it
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Any luck? I want to fix mine.
さんによる
I would like to know whether you found a suitable replacement screen also. I have a few irons in the fire at the moment. I will keep you posted as to whether I located a replacement screen.
さんによる
thank you, I'm keeping a close look out for a replacement too and will share any info that I find ...
さんによる
コメントを追加
Nope. I replaced it first by a Livescribe Echo 3 but this one is worse than the first. This pen degraded alltogether within days and I sent it back. Now I have a Ne Smartpen 2 but I still miss the incredible functionality of my fist Echo. Shame there is no real competition after all these years.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Two points really from my experience and I have had many of the pens as has my wife, one of which has a bearing on the second: 1) don't let your pen run out of charge and don't use it at full brightness ( I use mine at 10%), 2) if you buy a used one, beware that it probably is not functioning again if the battery has gone dead - enquire about the screen before purchasing and make sure you can return it if it isn't. It seems that it is a function of battery and battery type. The new ones that I have purchased and if they fail, Livescribe replaces without question but the supposed BNIB on ebay - beware. I did read a blog where the guy replaced the screen but you realy have to be a electronic engineer and have small hands and good eyesight! I agree, too bad there isn't more competition as the concept is exceptional for my work.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I also had (and have) this problem with my Pulse Livescribe Pen. The LED doesn’t work anymore. But I practice a kind of workaround. Using the headset, I completely trust on the audio instruction. And using the Record and Start dots, for me it’s a perfect and effective solution for years already. I also know other people do this. Kind regards from the Netherlands, ^JT
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I am also a victim of this design defect. I think we should demand the collective refund of the money and force the company to withdraw each and every one of these pens. We should not resign ourselves in silence with what seems to me to be a fraud.
In the box it says "NEVER MISS A WORD" and they should have added "AFTER 3 YEARS IT WILL STOP IRREMEDIABLELY AND CANNOT BE REPAIRED".
A producer of more than € 100 should have a much much longer duration.
さんによる
I face the same problem with two of my Livescribe pens. Thought the first one was defective, brought a second one. LED died after few months of use. No aftersale service. Looking for another brand of similar functionality. Hope better and more responsible products are available.
さんによる
コメントを追加
Use heat it will light right back up I used a heat gun and it lit up brand new just keep the heat on it no longer then 8 seconds at a time and I suggest you open it and exposed the screen add high temp heet and Bam
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Michael, you said keep the heat on for 8 seconds at a time. How many times do you do that and at what intervals? I'd love to recover the screen on mine if your method works. Thanks.
さんによる
what kind of heat?! i'm a girl, not a techie, can you give me a step by step please? the screen on my pen is out...
さんによる
Has anyone any more detail on this method?
さんによる
コメントを追加
To ALL Users of LiveScribe Echo Pen - CRAP el-cheap0 dud pr0duct - which is being SOLD Worldwide at ENORMOUS Retail Prices (USD $150+): There is LEGAL Action which is being investigated by International Attorneys, to REiMBURSE ALL End Users (Customers/Clients) for their LOST TiME and PRODUCTiViTY, trying to RESOLVE the problems and BATTLiNG with USELESS crappy LiveScribe “Customer Support” - which PROLONG the FRUSTRATiON of EXASPERATED and AGGRAVATED People.
Please send me any inquiries you have made to Livescribe Inc., Company, to the following e-Mail address: Chris0KenNZ@Gmail.com
Please include ALL your correspondence (including any Reference ID) with Livescribe Customer Support in chronological order, as an attachment (Wordpad or Word Document).
Thank you.
Christopher Kennedy
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same here, what a waist of money…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tammy さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 52
今までの合計 9,407
