メインコンテンツにスキップ
The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
40回答 すべてを表示
some general problems 1999 jeep cherokee sport
hi everyone ive had a problem with my jee here it is it staled on the freeway the other night long story short got it started like 1 hour later then staled like 20 minutes later we replaced the coil and now its running ok but after replacing the coil all my gauges are wacky sometimes one or two is on but mostly they are all off also very slow pick up so i manualy drop it down to first then second ect seems to work fine if any one has any ideas please holler at me thanks Tim
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sounds like you are have some kind of a heat problem. Go through the engine harness and look for damaged parts of the harness. Heat long term will make wires brittle and corroded. Short term heat creates resistance in electrical components.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tim buchan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 398
