メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Installed new rear camera but it's still not working!?
I followed the guide from ifixit to install a new rear camera after a minor fall crack the edge of the screen and the camera no longer functioned, but after a new camera and a new battery the problem persists!
The front camera works fine.
The rear camera is black. The flash does not function. There is a caution "overheating - wait for battery to cool" warning and the battery does overheat quite easily.
I have checked all the connections which seem fine, and not sure how to diagnose.
Help please!?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
If the battery is heating when this device is functioning then there's a short . When you installed the camera was there some sort of installation between the care and the camera or insulation at the connectors. There is a short probably against the care
さんによる
I think you mean case right, the aluminum body? I will reconnect all today but it all snapped into place fine before. I wondered if the camera was bad.
I have a multimeter. Can I check for a short on the case somehow? Is there a fix or would it require soldering?
さんによる
コメントを追加
1 件の回答
Try the soft reset or resetting the settings. It should work for you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dylanemcfarlane さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 121
