メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
88回答 すべてを表示
Why doesn't my iPod sync with iTunes via USB 2.0?
My iPod mini has recently suffered from battery issues, but it still charges. By battery issues, it has bad battery life. If it has a full charge, the battery will typically lower to 25% within a minute. I will replace the battery soon, but I don't think that is the cause of my problem. When I plug my iPod into my computer, it doesn't show up, and doesn't sync. The source of the problem is not my computer, as I have tried to sync the iPod with a PC running Windows 8.1 64bit, an iMac running Mavericks, and a MacBook Air running El Capitan. The iTunes versions are up to date on all operating systems. On some occasions, iTunes has given me an error message which told me to restore my iPod. When I selected the option, the iPod then ejected itself before anything could happen. I suspect the problem could be with the logic board. I am fairly new to these components, so any advice is helpful.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you tried connecting with a different cable? This could be the issue as well.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes. I have tried using the original 30-pin charger that came with the iPod. I have also tried using a newer 30-pin from a 4th gen iPod touch, as well as a 3rd-party 30-pin charger. None of these have worked. I can only charge the device, but syncing doesn't work... Thanks for the suggestion though. :/
さんによる
コメントを追加
回答を追加する
Austin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
