Where is the fuel pump relay?
I need more specific answer for 1998 Mazda 626 four cylinder. Where is the fuel pump relay?
Is it the relay marked EGI or the Circuit Relay?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@yetbo check the fuse box in the engine compartment. There are a few varieties, white relay (green relay) same location. Sometimes labeled as EGI and sometimes as Circuit relay. Location is the same.
. You can find great information on here
このアンサーは役に立ちましたか?
the second pic is wrong
the first pic has a jumper running to the fuel pump
過去 24時間: 5
過去 7 日: 39
過去 30 日: 138
今までの合計 15,209
1件のコメント
What’s the one in the middle on the bottom of the picture??
Darrold munden さんによる
