My dualshock 4 turns on then off again with 1 orange blink?
My ps4 DS4 is doing as title say's but only does this if u connect usb too it otherwise does nothing. Works in safe mode with usb connected tho, Nothing in normal mode.
Tried connecting it too pc with usb makes connection sound on the pc and lightbar on DS4 blinks once then off. Then tried too connect DS4 by Bluetooth too pc WIRELESS CONTROLLER appears in list with ready too pair underneath and pair button too push on screen. So try too put DS4 into pair mode where the lightbar blinks white (holding SHARE & PS BUTTON down) nothing happens so can't pair. Tried also resetting DS4 with thin object connected with usb will flash lightbar once does nothing if push reset without usb connected. Think that's everything I've tried just going too try connecting too my Android now, So PLEASE PLEASE somebody help me don't know what else I can do other than open it up and trying a few things...........
6 件のコメント
Managed too get connected on my laptop using usb and program called Input Mapper but not by Bluetooth laptop now sees the DS4 when in Bluetooth connection screen and say's ready too pair but will fail when I push pair as the DS4 will not start flashing when I hold down the share and ps button. I'm thinking maybe the PS button is not working. Anyone else have any ideas Please do comment, Thanks...
chris secker さんによる
Hi,
Just a thought. Is the DS4 battery faulty? Wondering if when connected to USB there is not enough power supplied by the USB connection to run everything and trying to charge the battery as well.
jayeff さんによる
tried the battery with and without, without battery when usb is plugged in the lightbar will flash orange real fast. But done a little more testing using it on pc where u go into the property's of the controller then select TEST then u can test all buttons and all buttons light up red when pushed on screen anyway all the buttons light up red except nothing happens when PS BUTTON is pushed so I put my good working controller in and that lights up red when
PS BUTTON is pushed. So what I've done is ordered a new flexi board for it which was about £4 and will be here in the morning. Will post the news once fitted tomorrow some time.......
chris secker さんによる
Hi!
I have the same problem. Do you fix it with the flexi board? That was the problem??
Juan Manuel Aguero さんによる
yep new flexi will fix it. fixed mine anyways...
chris secker さんによる
1以上のコメントを表示
