メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
After replacing battery screen doesn't work, It shows faint grid lines
After redoing twice the whole step by step I did to add the new battery, the screen is still unresponsive. I can see a faint grid lines and both slides to "UNLOCK" and "POWER OFF" don't work.
What can I do next to fix this unexpected problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
What color are the lines? If they're grey/white it's a sign of a poor connection and/or ESD damage. You'll want to power off the device (hold the power + home button simultaneously) and then disconnect the battery, followed by the screen. Take a q-tip (dipped in Isopropyl Alcohol if possible) and clean the connectors on the board for the screen and on the part. Let dry completely (this goes faster with >91% purity alcohol) and then inspect for any debris in the port(s). Plug in the screen, then the battery, and then power on the device.
Lines should be gone but if they are not you may try letting the device sit, disassembled for about an hour or two for the static to discharge.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
taf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 88
