screen is black no backlight
few years ago screen progressively went pinkish then black. Still works very very faintly and operates fine with an external monitor. Is this inverter board, cable , or the screen itself... thanks
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If I was to go by your title I would say it's inverter board/ cable, but since you also mentioned that the screen progressively died out it could also be the display went dead. I would get the inverter board and cable since they are inexpensive and easy to get and try that first. That failing, replace the display.Here is a link for the Inverter. Here are the Guides for your machine. Good Luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,250
