Touch ID Button glass cracked - repair w/o loosing fingerprint feature
Is there a way to just replace the glass on the home button? The Touch ID sensor does not work due to the cracked glass.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
No it's not possible, the sensor chip is thinner than human hair and extremely brittle. To make the matter worse, the chip is glued to the button crystal so there is no way to remove it without breaking it.
このアンサーは役に立ちましたか?
Thanks because I knew it could be repaired on iPhone 8+ but I was thinking because in my case with cracked button glass I was Not able too repair touch id.
you are always right n you are here :)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 440
