メインコンテンツにスキップ
This Apple Cinema Display is characterized by the M8149 model number and was first released in July 2000
7回答 すべてを表示
pink or red screen fix
I have two 20" apple cinema displays and one of them started giving a pink/red tint to the screen image. I was wondering if this is a common problem with a solution that I can repair myself. Any advice would be greatly appreciated! Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Check the number please, is this a A1081?
さんによる
The number a1038 is the correct numer on my display. It is an older model with the clear acrylic body. It is not the model a1081.
さんによる
The same is happening to my 22" Cinema Display ( 2000 ). Except it happens intermittently. And the change between normal and orange seemed to be always after the screen was moved.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Reddish color on any monitor/display is a faulty LCD.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
When I had this problem on my M8536, it was just because of a faulty cable. Try bending the cable around and see if you can find a sweet spot in which the picture has the appropriate colors.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
legendmacnet さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 11
今までの合計 1,144
