メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Water under phone screen: showing vertical white lines
So a few weeks ago I dropped my iphone 6 and in the top right hand corner the screen lifted a little bit from that corner almost all the way to the other side. The phone was still working fine besides freezing here and there. About an hour ago a few drops of water (a very little amount) got inside the phone from where the screen was lifted. Is it possible to have this fixed without needing a whole new phone?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
hi,
It all depends on where the water went to after it got into your phone. Best bet is to open your phone (check out repair guides on here if unsure) and have a look at any water damage indication. The top right of the phone is where you have the flex cables, so water could've got onto there and short-circuited the cables. You will need to take the screen off, check for water damage and clean all the connections for the flex cables. Let it dry out before reconnecting. I always find a 'power cycle' of the battery helps. (disconnecting battery from its connector, waiting 30 seconds and plugging back in again)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
marymccarthy20 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 3,991
