メインコンテンツにスキップ
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127回答 すべてを表示
Tablet wont download anything
Wont let me download anything and i cant get playstore only got market
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
2 件のコメント
I can't even find download manager in apps. When se arched it says 0.
さんによる
I've had this samsung tablet for about 2 years now I've only used it twice when i played music but i haven't used this for about a few months ago I got on here and now i can't listen to any music i now can't down load i don't know about tablets don't now what to do I'm very old you see
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
Not quite sure where it is located in your Tab but go to Menu > Settings > Apps > swipe right side to ALL Apps, then scroll down and find Download Manager. The Apps are listed alphabetically, with working apps first then disabled apps.
Tap to enter Download Manager. If there is an Enable button tap it then try to go online.
If it says 'disable' tap to disable, then clear cache. reboot Tab then navigate back to download manager and enable it as above.
See if you can access the internet with your browser.
このアンサーは役に立ちましたか?
スコア 6
6 件のコメント:
I tried everything offered on all of these sites on how to get my galaxy 4 which had suddenly stopped downloading to download a new book that I had purchased. Nothing worked. I cleared my entire library out thinking storage is a problem. Nothing. Then I decided to delete my existing Kindle app and reinstall a new one...boom! a perfect download within seconds! So this is my suggestion!
さんによる
Ive tried all this to no solution says browser no longer supported why
さんによる
@deboramchaffie
Have you checked that the tablet's date and time are correct?
Can you connect to the internet OK?
What is the model number of your tablet?
さんによる
@jayeff yes its all correct
さんによる
Model #ce0168
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Gordy Kinsman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 35
今までの合計 25,391
