メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
(Can't connect to camera) S3 i9301 with CM12
Some days ago I installed a Resurrection Remix Rom (I actually don't know which one, sorry. I just know that it's got Lollipop) and when i went to the camera it said: <<Can't connect to camera>>
I still had warranty, so I installed the stock rom (I checked the camera and it still didn't work) and I sent the phone to the company. IMPORTANT NOTE: In the warranty ticket it said <<SOFTWARE ERROR>>
The only camera I can use is the "selfies" one
When I received it, the error was fixed, so I tried to install another ROM, so I installed CM12. But... I got the error AGAIN and I haven't got warranty anymore
That's what I tried
-Install Reset Camera and Camera (CMFix) (Camera CMFix didn't open and I had Restart Camera Installed :v)
-Checking if an app is having troubles with the camera
-Rebooting in safe mode
-Holding down the volume/power/back
-Clearing Data and Cache of the camera
-Removing my SD card
-Renaming the DCIM folder
- youtube. com/ watch?v=Fa9qggQJ990 (I can't even access to that menu ._.)
-Find “Use NuPlayer” and uncheck it & restart
-Using other camera apps
-Disabling the Google Camera and using the default one
-EDIT: I installed the Stock Rom with odin and did a factory reset. I even did a "system reset" with odin. AND IT STILL DIDN'T WORK OMFG. Then I tried to update the camera firmware (youtube. com/ watch?v=Fa9qggQJ990) because I've got KK now, but the "Phone/CAM FW Ver Check" is disabled. I googled my camera Cam FW Ver and it's not old
Thank you, I'ts a really annoying error. My S3 is giving me too many troubles, I'm starting to hate it... But I can't buy a new one
OHMYGOD I CAN'T FIND A WAY TO FIX THAT ERROR HELP PLEASE
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
I had experienced the same problem,
I could solve it thanks to the fix given here for i9301q
https://forum.xda-developers.com/galaxy-...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Also CM is discontinued. Use LineageOS.
さんによる
コメントを追加
回答を追加する
Mario Ortiz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 996
