Why my samsung can't turn on?
my samsung galaxy s5 had only 16% battery left, so i listen to music over 1 night and in the morning my samsung can't turn on, i've charge it for 11 hour but still can't turn on the samsung..WHAT SHOULD I DO ?! HELP!
Update (12/26/2015)
Should i buy a new battery ?
この質問は役に立ちましたか?
3 件のコメント
When you have it plugged in to charge is it showing that its taking a charge or are you just assuming it is. Your problem may be that its not actually charging . Try a different cable or different charger , hook it to your computer and see if you can connect to it
Jimfixer さんによる
thanks a lot
luciancifer さんによる
so, i've try a different cable ( charger too) and it seem can turn on, but the problem is the screen is tonally black,..what should i do?
luciancifer さんによる
