Why won't my I-phone 5c phone charge? It is only 6 mo...old
when i plug my phone in, it does absolutely nothing.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If it's only 6 months old, take it to Apple, you have 1 year of Apple warranty, as long as no one has tampered with it by opening it, you should be fine.
If you have been using cheap charging cables and not original, then you will more than likely have damaged the U2 IC chip on the logic board that controls charging and sync.
I wouldn't mention about cheap cables or anything to Apple, if you have been doing that, they'll refuse to replace or repair it. :-)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 165
2 件のコメント
It should still be covered under warranty...????
oldturkey03 さんによる
Did you check to see what is inside of the charging port? Sometimes there could be
bug eggs, hair, dust, etc.
That's probably what may be causing to prevent it charging.
Priv さんによる
