Battery solder pad came off - How do I fix this?
A friend of mine did a bad job of soldering the new battery in.
In troubleshooting, I found that the solder pad on the circuit board for the white battery lead is missing.
How do I fix this?
この質問は役に立ちましたか?
2 件のコメント
As in the contact it solders down to on the board, or the solder that was originally holding it down? I de-solder those contacts, tin the wires on the battery well, then re-attach them using the fresh solder on the wires. This makes for a small new clean connection with little chance of a short.
Eric Essen さんによる
I desoldered and re-tinned (fresh solder) the battery leads successfully. I also desoldered and re-tinned the solder pads on the circuit board for the red and black wires successfully.
The problem is the copper pad on the circuit board for the white wire is missing completely.
My friend must have yanked the wire off before the solder was liquefied? I'm not sure.
Where the solder pad should be there is a brown mark and no copper pad underneath (I gently scraped with a burnishing tool to check).
Aud1073cH さんによる
