water-damage: Doesn't turn on after isopropyl bath
Is there anything else (cheap) i can try?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ok, so you cleaned the phone. Did you try swapping out parts? Like the battery? Or the lightning dock?
このアンサーは役に立ちましたか?
No, not yet. Is there anyway to identify parts that might have been fried?
The battery needs to be replaced. I would remove the battery, after the cleaning, then put the display assembly and lightning dock back on. Then plug the phone in. It should power on, but you'll likely just see the apple logo. This will tell you if your lightning dock is working
You need to remove the EMI shields and clean it properly, then replace the battery.
You HAVE to replace the battery, there's no cheaping out on that.
Remove the shields and put the board under a microscope and examine anything out of place
このアンサーは役に立ちましたか?
thanks, I'll try that.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 155
