メインコンテンツにスキップ
HD action camera with touchscreen LCD, released October 5, 2014.
87回答 すべてを表示
How can I replace the touch screen?
I just bought my replacment rear screen yesterday i tried to replace it, but i couldn't remove the original. I could tear down almost totally (i removed even the battery box) but then i stuck. Thanks for any help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
6 件のコメント
Thanks for your answer, but in the meantime i could replace it, and it solved my problem, now its like i have a new camera. It was tricky with that button cable but i made it work.
さんによる
How hard was it to replace it? Did you use a tutorial? I can't see to find one online
さんによる
Tom - can you please share how you replaced it? I can not figure out how to remove rear lcd without damaging anything and all tear down videos I've watched do not show this being removed.
さんによる
I just replaced mine last night. it is glued to the black frame and has to be gently pried and re-glued. You may have to transfer the touch screen on/off toggle switch from the old screen assembly if the replacement you bought doesn't have one. Mine didnt so I had to remove and re-solder the button. Takes some advanced skills to do it but it was very quick and easier than I expected. I did crack my front lcd while removing it but it was already broken and needing to be replaced. It is also glued down.
さんによる
Where did you buy the replacement touch screen?
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
You might want to read my additional comments in my topic:
Saltwater drop / Rear LCD not working
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tomi H さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 3,460
