メインコンテンツにスキップ
2012年後期に発売されたGoProの第7代目モデルです。1080p30ビデオ撮影、60m防水ハウジング、Wi-Fi対応。
18回答 すべてを表示
Can't turn on Gopro on battery after water damage. Works on USB.
Hi everyone,
A few months earlier, I got my Gopro immerged into pool water. I didn't see it immediately, but around 2 weeks later, when I tried to turn it on, I couldn't : no reaction from the camera, the screen kept off and I had no LED indicator.
However, the camera works finely when alimented by USB cable... The problem is not coming from my batterieS : I tested 3 different ones.
I'm suspecting a disease somewhere on the motherboard between the battery connector and one of the component because as I said, the camera has no problem on USB. How can I repair it to make it work again on battery ?
Thanks for the good work you're providing on this website.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
The expansion board might has some effect on the battery's charging and the usage of the battery.
Remove this part and see if the battery works fine. If so, replace.
GoPro Hero3 Silver Expansion Port
GoPro Hero3 Silver Expansion Portの画像
製品
$6.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Any news on this?? Bump, my out put at the cameras battery ports were at 1.7v@.2A
oms @17.5
Update (03/17/2016)
So I try ed to replace this item and I get get positive feedback, the item turned on a lot faster,but I did not change the cable out, I did notice that it does need to be changed as well,and I have a live show of what happened when I turned it on that I could upload if anyonecares??
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
upload if possible
さんによる
コメントを追加
回答を追加する
Maxime Zackrisson さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 12
今までの合計 1,072
