メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
478回答 すべてを表示
iMac will not power up led 501 is on
Due to my 2 year old boy taking my iphone 6 charger-plugged into imac and then putting the other end into an outlet my imac and most things connected to it have died.
I suspect the motherboard, but I am asking if anyone could confirm that via the last light being lit led 501 the one on the right. No change when i hit the power button.
Thanks for your help
Yes I spanked his little xxxx
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Yes LCD is plugged in and Ram is still installed
さんによる
That last LED light is sensing whether or not the LCD is sending/receiving a signal from the LCD. This would lead me to believe that either the LCD itself is out OR the graphics card isn't seeing it for some other reason. Do you get a boot chime?
さんによる
I do not get a boot chime
さんによる
Do you hear the HD spin up the OD checking for discs? Any fans spin up?
さんによる
Nothing spins at all no sound at all
さんによる
8件以上のコメントを表示
コメントを追加
1 件の回答
選択されたソリューション
Okay, it sounds like the power supply itself has gone out, I'm assuming the 12v rail and maybe a few others. You might want to consider pulling out the logic board and having a good look at the capacitors to see if any are popped, or bulging (They should look like little pop cans that are flat on the top).
Also inspect the board for any scorch marks around components.
If you're interested in attempting to replace it the Power supply ifix it carries the part: iMac Intel 21.5" (Late 2009-Mid 2011) Power Supply
And you'll want to follow this guide:iMac Intel 21.5インチ EMC 2428の電源の交換
Gotta love kids! :P
iMac Intel 21.5" (Late 2009-Mid 2011) Power Supplyの画像
製品
$69.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Robert2316 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 1,169
