My iMac Doesn't power on
My iMac doesn't power on - sounds like it is dead. It was in storage for over a year. worked fine before. change the pram battery but it still doesn't work.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Open it up and look at the 24 cans (capacitors) for swelling or leakage. If they are OK. press the reset and the restart buttons on the logic board and observe the diagnostic lights and tell us your results.
このアンサーは役に立ちましたか?
one of the capacitors is blown.. if i change the one will it fix the problem?
If none of the others have failed you have a good shot. The definitive expert on these caps is Jim Worholic. Check out his information here: http://jimwarholic.com/2008/07/how-to-re...
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 355
