Touch not working after replacing screen
I replaced the digitizer only an iPad 3rd generation. I haven't sealed it. It does come on and Siri comes on but the touch isn't working. Help!
If possible, remove the new digitizer, and test the old digitizer to make sure it's not an issue with the iPad's logic board.
If the old one works, you'll know you need to replace the new digitizer as it would likely be defective.
このアンサーは役に立ちましたか?
I can't put the old one back on because it shattered.
I should say I shattered it when I took it off. it only had a crack prior to my replacing it :(
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 94
