People can't hear me when I call them
When I make a phone call people can't hear me but I can hear them my phone is not on mute the only time I can be heard is when I have my headphones on
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
If you can be heard when you are using the microphone attached to the earphones but not when you are just using the phone, it points the problem being a faulty or loose internal microphone.
One way of double checking this is to open the Sound Recorder app, record your voice for a few seconds, then play it back. If you hear nothing it definitely points to the microphone.
The microphone is located under the small paperclip sized hole at the underside of the phone. This opening may be blocked. DO NOT try to clear it by inserting anything in there, you may damage the microphone. You could try using a vacuum cleaner and just briefly hold it over the opening (it may remove any blockage) and then see if the microphone is now working. If it still doesn't work, check to see if your warranty is still valid and if so either contact the retailer or the manufacturer (depending on what your warranty states) about getting it repaired etc.
このアンサーは役に立ちましたか?
I have a tablet I have tried everything I can think of
Couldn't find answer
It is a tablet they can't hear me either way
Hi @justmenow
What is the make and model number of your tablet?
When I go live nobody can hear me and it makes me up set
I had the SAME problem with my IPhone SE and all I had to do was restart it!
このアンサーは役に立ちましたか?
So we have to restart it again ? so they could hear me
If my wireless speaker is hooked up it only puts out sound not voice.
I can hear them good but my phone is breaking up too them
I solved it. I had installed the OK GOOGLE option and all was fine unless I had used the speaker at anytime on any call.
So if you look up in settings the OK Google you have option of using it just on search screen or when you are on ANY screen.
Get rid of the any screen part and wahlaaa.
このアンサーは役に立ちましたか?
Did anyone try this fix of changing the "ok Google" option? Have had no trouble since.
I don't have the OK Google option on my phone and I still have the problem.
The best solution that worked for me was the one Ann Johnson gave. Thank you very much "Ann Johnson"
i also benefitted completely from simply disabling the ok google settings.. i am back to having static free mic! ;P
If you're using a wireless speaker it puts sound out and will not project your voice and check your Bluetooth settings.Go thru your apps .and restart your phone.
このアンサーは役に立ちましたか?
Hi @shane_24 ,
You could try wiping the cache partition in the phone and check if this resolves the problem.
Do not select wipe data/factory reset as this will erase all your data and downloaded apps.
Also try starting the phone in safe mode and check if an ordinary call works OK.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one. You’ll need to uninstall each downloaded app, one by one, and test the phone in normal mode between each uninstall until it works OK. When it does then the last downloaded app that was uninstalled was the culprit.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 10
過去 30 日: 43
今までの合計 328,946
43 件のコメント
When will the problem get fixed
capnineteen56 さんによる
I have the dame problem
shiningsmile30 さんによる
The update didn't work for me
curt216 さんによる
I have this problem, and this solution doesn't work for me.
wm2 さんによる
Same, nothing working to fix this
dawn richardson さんによる
38件以上のコメントを表示
