Removing vent window pins
How do I remove the pin on vent window handle
この質問は役に立ちましたか?
この質問は役に立ちましたか?
you should remove the framework of the window so as to not break the glass then you can either replace it as a unit or drill the pin out and replace it with a roll pin later
このアンサーは役に立ちましたか?
I took a long punch and ground about a inch or two down until it would fit in the hole making contact with the outside of the roll pin. With the window out of th truck very carefully tapped out the pin.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 271
