Blower fan replaced and still not working.
I have checked the fuses and replaced the blower fan on a 2000 beetle and it's still not working. What else could the problem be?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Check the blower resistor and the switch on the dash itself. You may want to check the blower fan as it is possible to get new parts that are doa. A quick test is to wire it direct to the battery. Use a multi meter to test the switch and the resistor. The resistor will be found on the wiring just before the fan and it will go in the duct work for the fan just before the blower
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 447
