why is my screen white??
i unplugged my iPod from the computer and now it is white. i tried to reset it and it turned white and beeped 2 times. i tried to restore it and now my screen is gray
this is an indication of an LCD or logic board failure - contact Apple to get it replaced :(
このアンサーは役に立ちましたか?
IF YOUR NANO IS UNDER WARRANTY CONTACT APPLE.
If the failure is cause by water intrusion the best course may be to sell it on eBay AS-IS.
If none of above apply, you may consider a screen replacement.
Several generations of Nanos, all seem to suffer from LCD failure, "White screen of death"
This can sometimes be fixed by an LCD screen replacement.
Fortunately, on the 4th gen Nano, this is a relatively simple, but should only be attempted by an experienced technician.
See Fixit guide on this website
Replacement screens may be purchased on eBay for ~$10.
このアンサーは役に立ちましたか?
I have the same problem.
Did you change your screen ? And do the iPod walk now ?
このアンサーは役に立ちましたか?
Panasonic telephone screen stays white?
このアンサーは役に立ちましたか?
Why is my panasonic screen white?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 4,665
