メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
My iPod charges but doesn't say is charging.
My ipod charges but doesn't say it's charging. It charges very slowly. However, sometimes (very rarely) it recognizes that is being charged and then it charges at a normal speed.
Same issue when connected to a dock, computer or usb of a car radio. Doesn't seem to be the cable since it works with other devices and several cables have been tried.
Any thoughts? Could this be because of the 30 pin connector or a major hardware issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Joel that could be caused by your dock connector. If it is a major issue, you need to take check it for any bend, corroded or broken pins. If it looks okay than you need to consider having it re-soldered or exchanged. Not an easy task and requires some good skills, tools and practice.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 78
