heat then I see almost 100degrees celsius
by the way im new only
i have laptop g60-249wm and also i cleaned the fan and fan is working correctly and i have already too cooling fan in down on notebook or laptop
and
always get a heat and i install some application that can read about heat then i see almost 100degrees celsius i got i dont know how im adjust the brightness that can more longer heat and it was -8 degrees celsius and now its 92deg......... but it still hot is there anything too make this low ???? im always sad because of this :( feeling bad with hp g60-249wm
i feel you answered this soon :(
この質問は役に立ちましたか?
Try running the laptop on power saving mode or balanced mode, that helps a lot!
Ayy Lmao さんによる
well already do that and now its 80 but is thier anything upto 50degree celsius or less ?
cbpwin さんによる
