" There was a problem with the network [406]
Try to connect with You Tube but got the above message.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Does it only happen with your You Tube app? If so, see if there are any updates available for the app. If yes, download and install the update and see if it resolves the problem. If it still doesn't work or there are no updates available, uninstall the app, then download and re-install the You Tube app. Hopefully this should resolve the problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 179
