メインコンテンツにスキップ
The BlackBerry Bold 9900 is a smartphone with full QWERTY keyboard and touchscreen.
25回答 すべてを表示
Phone wont switch on
Hello have a phone problem ,it doesn't switch on the screen is black even after I changed batteries===
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
4 件のコメント:
We seem to be having the same problem, mine only flashes red when u try to put it on but yet remains blank
さんによる
same problem
さんによる
My blackberry bold 9900 won't turn on I tried a new battery and it only worked for an hour or 2,then I charged the two batteries else where it also for an hour or two . when plug in the charger the led light turns red and u only see battery charging sign that's all.
さんによる
Same problem
さんによる
コメントを追加
1 件の回答
Hello geraldmtshali,
  • install blackberry manager
  • Connect the phone via m.USB cable
  • Update the firmware if available otherwise you can do the repair the phone by blackberry manager
  • Fallow the instruction
Hope above steps will help you to fix your BB
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
I removed my battery out of my phone, then when I put it back in again which was about 1 hour later it wouldn't turn back on, it has no LED flashing at all, I've tried plugging it into the charger and nothing happens and plugged it into the laptop that also done nothing. The laptop doesn't even realised I've plugged it in.
Can anyone help?
さんによる
Hello shuvo, does BB manager detects your phone ?
さんによる
no brother its not :(
さんによる
Then it should be hardware fault. simply you can check the micro USB connector either it physically damaged.
さんによる
コメントを追加
回答を追加する
geraldmtshali さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 5,376
