My phone wont charge and wont turn on
The phone. Is blank. No red light and it wont turn on
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Have you tried charging it with a USB cable connected to a PC?
If it charges, you have a faulty power adapter and need to replace it.
Allow your phone to fully charge before you turn it on.
If it doesn't charge with the USB cable connected to a PC, you either have a faulty charging circuit in the phone or a faulty battery.
Hi,
Not sure what it is you want to find.
If it is the USB cable, what you need is called a "micro USB to USB cable". This is what the ends of the cable looks like. You plug the small end into your phone and the bigger end into a USB port in a PC. It is available from Walmart, Ebay, Amazon etc.
If it is a new power adapter that you need here is a link that shows a power adapter with a USB cable that is suitable for your phone.
このアンサーは役に立ちましたか?
We're do ii find one
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 488
