メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
63回答 すべてを表示
2 beeps,black screen plz help
i hold the power button for a couple seconds and it beeps 2 times i tried taking the battery out and couple more things and it beeped yesterday then i toke the battery out and turned it back on with the battery on it worked .PLZ help me
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
brittany2015, 2 beep POST beep is a No Memory (RAM) detected error. This could be the memory module as well as the memory slot failure. If you have more than one module. Pull one at a time and see if it POST properly. If you only have one, you may need to re-seat it or clean the contacts where it sits in the memory slot. If that does not fix it, and if your able to see the Dell Logo at startup, press F12 at that page. Select Diagnostics, and run an extended diagnostics on your computer. Worst case scenario is a slot failure which would require a new motherboard.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
i tried the F12 thing it didnt work but thanks for your help
さんによる
This can also to be the cmos battery my cmos battery is dead and removing that battry the computer boots up to say cmos battery failure but if u press F1 it will boot to the os and if there is no os it will just say no os.
さんによる
コメントを追加
I know this is an old thread but it came up when I googled my problem so I imagine it must come up for others as well. I had a black screen with a double beep alarm. I took it to geek squad where they told me that it was 70$ to run diagnostic and 350$ to replace parts. I took my dell home and removed the. Artery and the panel on the bottom with the small screw. Inside the memory panel is right in front of you. U click the little grey plastic holders on the side and the memory card will tilt upwards so you can slide it out. Just like an SD card. Take it out and reconnect it. My computer works like a charm. Hope this helps.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
thanks for taking the time..
さんによる
コメントを追加
回答を追加する
brittany2015 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 42
今までの合計 11,240
