iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
3267の回答 すべて表示
The phone will not let me erase it
It will not let me erase content it just stays on this turning sprial in the middle of the screen I forced a restart and tried to go threw settings to do it again but still no luck
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Did you hold down the power button and the home button at the same time until the screen goes black? That will force it to restart.
による
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
Ok how do I do the third option ? Please walk me threw step by step!! Thanks so much guys !!!
この回答は役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
DFU Mode Restore.
Open iTunes on computer. Connect iPhone to computer with USB Cable. Hold both home and power buttons for exactly 10 seconds, release power button, keep holding home button for about 20 more seconds until iTunes recognizes iPhone in Recovery Mode. If the iPhone screen is black this is actually DFU Mode. Then Restore iPhone with iTunes. Done.
この回答は役に立ちましたか?
スコア 1
コメント:
I second this.
による
コメントを追加
It seems to be an issue with the operating system software. There are at least three ways to get your phone to turn off. One is to force restart it (home and power button) and let the software reset then shut it down. two, turn the phone to never auto lock and force the brightness to full power until the phone powers down. That's if you have access to the settings and your phone is not locked up because of a bad install. The third option is to force the phone into DFU mode after the restart and erase and restore all the software.
この回答は役に立ちましたか?
スコア 0
コメント:
The phone turns off I'm just trying to erase all the content on it so it can be given to my daughter ... It was my other child's phone and she had it jail broken .. the phone won't let me reset and erase all content .. It starts off by working and the apple icon appeares on screen for like 30 seconds with a bar under it than it disappears and goes to the spinning searching icon and stays thst way the phone is fully charged it and I left it in this state for 3hrs till I forced a restart to try again... I did this 3 times HELP!!!
による
You need to perform jcarm75 "third option". You need to put the iPhone into DFU Mode and Restore with iTunes on computer. This is the only fix because you are stuck in the Jailbrake. DFU is the only solution.
による
コメントを追加
回答を追加する
sillypeach26 さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 54
今までの合計 2,050
