メインコンテンツにスキップ
ガス、IHストーブ、レンジ、オーブン用コンロの修理ガイド
129回答 すべてを表示
Smooth cook top stopped working is it fixable?
My stove top "popped" and went dead. Is it fixable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
saustinwright possibly. At least you should tell us the make and model of it.
さんによる
The actual problem is stove causes the electricity to go off.
さんによる
@richjulia384
What is the make and model number of the stove?
Does it blow the fuse (or breaker) when not in use i.e. no controls operated to start a cooking function or only when going to start to cook by turning on an element etc?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
When you hear a stove top pop its likely an element or if its really old with glass fuses it could have just blown a fuse. Is your stove a glass top or open element stove and what breed is it. when it popped did you see any smoke or flash?Were the burners running (heated up) when you heard the pop or did you just turn it on. if it was running how long had it been on and are all the stove top element not working. it could also be possible you blew a fuse on your breaker box might wanna check that
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
saustinwright さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 989
