メインコンテンツにスキップ
モデル番号A1320/8もしくは16GB容量
154回答 すべてを表示
My iPod screen is turning white is this fixable?
the Ipod felt on the floor and when I plugged it in too my computer the screen turns white... everything is working only I can't see what is playing and i can't choose a number because the screen is always white. is this fixable by myself??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
I noticed you never got an answer to this. Are you still having this problem?
さんによる
コメントを追加
2件の回答
最も参考になった回答
The iPod has a liquid crystal display. A very thin capsule with a chemical compound which builds up the picture under an electrical charge. Likely is this capsule ruptured as a result of the fall.
There will no longer be any picture or pattern. All you are seeing is the electroluminescent screen (backlight) which shines through the crystals in the display.
This must be replaced as a complete unit. Relatively easy on the 4th gen nano.
The contents of the display are regarded as toxic so take precautions if you see any of this inside. Mop up carefully with camera lens tissues.
After plugging in the replacement give it a quick try before pushing it all back into place.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
if i don't have a replacement for it can't i be give any other sol'n to solve this problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,021
