メインコンテンツにスキップ
The Keurig K75 Platinum Brewing System is a premium single cup home coffee brewing system by Keurig.
21回答 すべてを表示
締切られた回答
Doesn't fill to the right water level
My Keurig has the following issue: When I brew a cup it is not filling to the appropriate water level. (6 oz will only brew on the 8 oz setting) I've noticed that in the refill tank there is this rubbery thing and as coffee is brewing, water is leaking out of that back into the tank. Does this mean the water pump is broken and needs replaced or is it something else.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Mindy, that is actually a check valve. When the water tank outlet sits on it, it opens that check valve. You could another reservoir, or check the valve in the base. It is not your water pump since it does fill it up when you set it to 8oz.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 11
今までの合計 235
