メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
903回答 すべてを表示
Plays only out 1 speaker, but headphone jack is not the problem.
I purchased this ipod on ebay and it works perfectly, except it would only play through one channel. If I pull the headphone plug out slightly, it will play through both speakers.
I have fixed a fair amount of headphone jack problems, so I ordered a new hp jack and installed it. The problem is still the same, even with the new jack. I even took a jack out of another ipod I knew for sure functioned, and still it's the same! It seems odd because if it were a problem with the motherboard/ribbon wire clip, then pulling the plug out slightly might not make a difference in the speaker channels. Then again, I'm not sure. The ipod doesn't look like it's been opened before I received it.
I can only conclude that the motherboard or the ribbon wire clip connections are bad. Has anyone else been equally perplexed by this problem, or have any advice on how to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
I have a fifth generation that is doing the same thing. I just replaced the headphone jack and it is still doing this. I had to put a disk drive in. The plug was only a few bucks but I see new motherboards from $30 to $60.
Did you replace the motherboard and i works now?
さんによる
Saame thing with my classic Ipod. I've noticed that if I apply pressure on the face of the device, just above the wheel, it plays out of both. Definitely not a headphone jack issue (I've tried many headphones). Just thought this new info might give some clues to someone else who's daring enough to open it up.
Graham
さんによる
hey,
i have the same problem with my ipod classic 120 gb. already replaced the headphone jack and still can't hear on the right headphone.
did anyone solved the problem yet?
i don't want to replace the logic board, it's very expensive and i'm not sure if this will solve the problem.
thank you and greetings from germany.
so long,
christian.
さんによる
コメントを追加
3件の回答
最も参考になった回答
- if pulling out the plug slightly makes it play through both speakers, do you get same channel through both, or do you get both channels?
If you get both channels, the problem should be located between the jack and the plug. Could it be that for some reason the plug gets in too deep?
If you get same channel through both speakers, then I will agree on your conclusion.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Yes, pulling the plug out slightly results in both earphones working... but not to full capacity. Both are notably quieter than before, and there are elements of the audio, usually backing vocals/harmonies that are inaudible
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How dit you fix it? :/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kyle Runyan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,515
