メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
914回答 すべてを表示
締切られた回答
Replace battery now have a white screen
I'll give a little history. I replace the battery before the iPod would not turn on with out being plugged in. I got a replacement battery and now the iPod has a white screen.
I also cracked the screen. I don't know if the cracked screen is the source of the white screen. It also charges up.
The iPod boots up with white screen. It connects to iTunes. I reset the iPod in iTunes it reset loaded the music into it.
Should i replace the screen on iPod, is it worth it? Any way of testing to see if it's something else.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Brendy I now have no white screen, it's black . I had really hard time getting LCD plug to go in. I got there now nothing. Thanks for you help!
I'll be buying a screen tomorrow.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Did you crack the screen when replacing the battery? If so it sounds like it's the source of the white screen.
I'd recommend disassembly to unplug the screen and then plug it back in. If it's still white It would need replaced.
Try that and report back :-)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 46
