メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
This is a laptop designed and manufactured by Lenovo for entry level business applications. This model number is WB0201130E.
14の回答 すべてを表示
Why won't my device turn on?
Hey,
Recently, my laptop having probem turning on. I don't know if its hardware problem or software. But i think it is highly due to hardware problem because there is no light indicating my laptop is on.
Pls help me to find out what might be the problem and how to fix it.
Thanks.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2件の回答
選択されたソリューション
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
この回答は役に立ちましたか?
スコア 4
コメント:
The shot gun approach?
さんによる
Seem to answer this one alot so I made a template for ron
さんによる
コメントを追加
If your device is not turning on it could be due to a number of causes. Please refer to the device troubleshooting page for more information on what may be wrong with your device.
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
tuvshintur さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 19
今までの合計 1,062
