メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Optical drive on MBP will not recognize cds but will recognize dvds?
Hi. I have a optical drive in a MBP A1150 that will recognize and play dvds, both blank and "with content", but the drive will not recognize any form of cd, blank or "with content". The OS is 10.5.8 and the machine has been fully updated. Can the lack of cd recognition be a software problem or an internal mechanical problem to the drive? Any suggestions would be greatly appreciated. Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
The first thing I'd try is a lens cleaning DVD. These cost less then a replacement drive and may solve the issue. However, if the issue is a bad laser then you have to replace the whole DVD drive. Here is the guide on replacing the DVD drive.
The part is a 12.7mm IDE slot load drive, if you cannot find the official Apple part. I would suggest getting the Apple official drive if you can, because iDVD may not work, depending on how old the version is. If you do not care about iDVD, I'd suggest doing this. The prices are a lot more agreeable on the non Apple drives.
If you need iDVD, you can find the Apple drive from iFixit and other places that sell secondhand Apple parts.
Replace a broken or damaged 8x SuperDrive for MacBook or MacBook Pro 15" with this part.の画像
製品
MacBook/MacBook Pro 15" 8x SuperDrive
$69.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
fritzj213 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 10
今までの合計 1,468
