メインコンテンツにスキップ
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
40回答 すべてを表示
Why can't I install the usb driver?
After installing windows 10 there were a couple missing drivers. I troubleshooted the laptop in devices and printers and it fixed all the driver issues except for the USB2.0-CWR driver. It says it doesn't have it. I tried to update it from device manager but it says windows can't find the driver, go to the manufacturersame website. I couldn't find it on dell.com either. What should I do?
It says in properties that the drivers for this device are not installed. (Code 28)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
have you updated windows 10 yet it could help
さんによる
I'll try that thanx.
さんによる
Ran a bunch of updates. Didn't change it. I had a problem on an hp pavilion recently where it didn't recognize the DVD drive. It seemed like a driver problem but was actually something in the registry that needed deleted and then it worked fine. Could this be something similar?
さんによる
コメントを追加
4件の回答
ベストアンサー
Hi,
Did you try this link, scroll to bottom and download Realtek USB 2.0 card reader?
http://www.driverscape.com/manufacturers.... If you have please ignore.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks, Jayeff, your link worked great.
さんによる
コメントを追加
down load driver genius it should find the driver.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey! It is easy! If you can't download drivers from official website, you can try to use a 3rd-party driver program to download driver for Windows 10. More detail: http://goo.gl/5h6ICN
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
maybe you should look for the driver Sesua, try visiting http://www.aiydriver.com and find your laptop drivers
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jesse さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,495
