メインコンテンツにスキップ
Aspire 5315 Series features Intel Celeron mobile processor and Mobile Intel GL960 Express Chipset
Why doesn't my laptop start up?
Cannot turn on my computer!
Hi!
Cannot turn on this laptop.
If I plug it in with battery in - status LEDs are indicated as:
Power/Suspend LED - lights up red;
Battery Charge/Discharge LED - bliks red;
If I plug it in with battery out - status LEDs are off;
When I try to turn computer on in both cases Power/Suspend LED turns on green for a half second as soon as I release the power button and I can hear as ventilator span on, but after half second it all turns down and returns to previous positions.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Having the same challenge with my acer laptop. What's the issue with acer gadgets?
さんによる
コメントを追加
3件の回答
After looking into this a little bit, here's the first thing I would try.
Remove the battery from the laptop, and unplug the AC power cable from the laptop.
Hold down the power button on the laptop for 1 minute, and then let go.
Reinstall the battery, and plug the laptop into AC power.
Try to start laptop now.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Greg,
I tried your solution, but unfortunately it didn't help, the laptop still won't start up.
Ted
さんによる
コメントを追加
Take your computer to a store, let the professionals to do the trick.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I Once I removed the image cable from my laptop and re-inserted it correctly, the laptop suddenly turned off completely and it does not turn on without battery or with battery,Even the charger does not turn on And it has no symptoms and is off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ted Herba さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 306
