Wifi Connectivity is not working
I am not able to connect to wifi, what could be causing this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Tim!
You may be in luck; most WiFi issues can be solved by changing software settings. This article contains a lot of good information that can be used to figure out exactly what is wrong with your wireless connection.
If you've tried everything in this guide, including a full Factory Reset, and your problem persists, a piece of WiFi-related hardware inside your tablet may have failed. If you believe this to be the case, you can replace the WiFi/Bluetooth antenna by following the Antenna Replacement Guide for your tablet.
Please note that WiFi hardware rarely suffers hardware failure, and that the vast majority of WiFi issues can be solved in software.
Happy Fixing!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 766
