メインコンテンツにスキップ
Kindle 3はAmazonによって発売された第3世代のKindle製品です。Wi-Fiもしくは内部ストレージが4 GBの3Gコンフィギュレーションです。
pages keep changing by themselves
The pages keep changing by themselves constantly. It is no longer possible to read
a page completely without it changing to another page.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I had this problem too. Getting no joy from Amazon I just put it into a drawer and forgot about it. Then some months later I took it out again to try the suggestion given above, but found that the battery was flat. So I charged it, turned it on, and it has never page-skipped since. Have no idea why flattening the battery fixed it, but anyone else with this problem should try it too, you never know!
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
Found this info which might be of relevance.
"Turn the page automatically"
Turn on Text to Speech, turn the volume all the way down, play with the speed until it matches your reading speed (press the Aa button to speed up or slow it down.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi,
The info in this link may be of interest to you.
http://kindletips.slickferret.com/?p=42
さんによる
Hi,
Found this info, it might be of relevance.
From kindletips.slickferret.com Tip #11 Turn The Page Automatically
Turn on Text To Speech, turn the volume all the way down, play with the speed until it matches your reading speed (press the Aa button to speed up or slow it down.)
さんによる
コメントを追加
回答を追加する
julia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 28
今までの合計 7,863
